OK, get your mind out of the gutter ! Well after fixing the bogging problem , next day.....BAM ! when It shifts from 1 st to second ONLY, the other shifts are smooth , as the always were.
Is there a modulater valve of some type ? seems odd to only happen from 1st to 2ed and it started suddebly.
'86' van auto trans. 2wd
. It might be a failing universal joint. While sitting still, foot on brake, shift from D to R & back again while listening for a clank. You might also try that while somebody is watching the drive shaft. Compare movement between front & rear joints. If one moves more than the other, then I'd replace. 84 & 85 vans have replaceable joints, so at least there's that.
