I replaced the water pump on my 84 back in 2007. It just recently started to leak again. I noticed when putting the new one back on that the larger bolt at the bottom which goes on last and goes over the alternator bracket doesn't cinch down tightly. About a millimeter of play in it. Is there supposed to be a washer under the bolt? Perhaps that was the reason for the leak. Obviously there has to be some play in it so that the alternator bracket will swivel to some degree when adjusting the belt, but I don't think it should be as loose as it is. Or perhaps there is crud inside the engine threads.
It just seems like a strange design for Toyota. Either the 2 bolts on either side of that larger bolt are enough to keep the water pump mounted tightly and there is no passage for coolant around the looser larger bolt or the bolt should be torqued down tightly and thereby not allow the alternator bracket to swivel at the lower end.
Any ideas?
. Tim
. Can't see everything from this picture angle, but a couple things jump out here. That adjustment bolt should have a wing-nut head (so you can adjust with your hand pressure). There is also an extra nut between the bracket and the threaded block (no call for one here). That stuff doesn't really matter much though (should still work). The real issue is having a loose belt when the adjustment is maxed out. That could only be due to a belt that's too long, having the incorrect mounting bracket(s), or having the incorrect alternator installed. The van alternator has the mounts (upper & lower bolt holes) oriented 180 deg apart. Here is a 4y engine with the correct alternator & hardware. This is where the adjustment should land with a new belt installed:
I discovered this while trying to adjust the alternator and the pivot end of the bracket was just dangling. Does anyone know where I can find the part number or dimensions? I'm thinking it might be either 91611-60830 or 91611-60865. I'm afraid to drive it anywhere until can replace it so any help is greatly appreicated. Thanks!
) I'm a little peeved as the kid i bought it from had a dad who owned an auto shop so i assumed it had been taken care of - fluids check regularly, problems fixed etc.
