Results 1 to 9 of 9
Thread: Crankcase overfilled
    1991 Toyota Previa DX
    Sep 2014
    Tucson
    Hi All,
    My engine oil overfilled from the reservoir, what causes that to happen and how do I top it from happening? Will that make the engine to run rough? And if so why? What needs to be repaired?
    Re: Crankcase overfilled
    This system has a self diagnostic feature. Does the "oil level" light remain illuminated after the engine has started? If so there is a code stored. You'll need to put the ECU in a self diagnostic mode to read codes. If you don't already have one it's a good idea to pick-up a factory service manual. Section LU goes into detail on how to diagnose and repair the system. Tim
    Sep 2014
    Tucson
    Can anyone help me find the manual (looking for free download PDF ) ? 1991 Previa DX My EGG is old and tired , but I love her . I going to squeeze every mile I can get out of her. Thanks to all of your input ! The problems are great, and the funds are low. But we get through this ! Thanks, FreeSpirit
    Here's one for you: http://www.ebay.com/itm/1991-TOYOTA-...b19fb8&vxp=mtr
    It would be smart to snatch that up as they rarely surface for that cheap. Yes the cover is messed up, but the information you need for this and countless other things is in there. BTW, to my knowledge, nobody has made a PDF of a Previa service manual yet. Tim
    1993 Previa 2WD
    Sep 2012
    Dallas, TX
    PDF manual was made a long time ago on a different forum... it disappeared for obvious reasons
    this issue is common... easy fix is to just disable it so that it won't pump oil from the tank any more
    WA State
    x2
    My '91 had a sticky level sensor in the sump. I finally just quit filling the reservoir under the hood and kept an eye on the oil level with the dip-stick.
    Seems that a replacement switch (89491-28030) from Toyota is over $300.... It's a peculiar affair with a donut that floats up and down on a spindle. It degrades and the float either sticks on the spindle or sinks to the bottom, telling the system to pump oil from the reservoir. If the float switch can't be trusted, and you can't stomach the idea of spending $300+ for a replacement, you're better off abandoning the system and checking the oil directly like any other car.
    Sep 2014
    Tucson
    Thanks to all who have responded, I have abandoned he system .
    1995 Previa LE SC
    Jun 2022
    Colorado
    How did you abandon the system? I get a flashing light if I try to take the fuse or disconnect the electric. Thanks
    Jan 2022
    Beaumont, TX
    I just unplugged the pump that is located on the bottom of the oil reservoir under the hood. It is bad to overfill an engine with oil. I unplugged mine over 20 years ago and all has been great since.
