I have a problem that needs some consultation. My very low mileage '88 cargo van (5-speed with 4Y engine) was running almost daily for the past year without incident, until a recent oil change, where the valve cover gasket was found to have a leak that required its replacement. (no prior oil leak had been detected at its parking spot)
Abruptly, the engine also began to misfire intermittantly, apparently on one cylinder, with "check engine" light on (also intermittently). After replacing the gasket, analogous symptoms persist: normal idle, but intermittant rough running, with brief (<1 sec) power drops at intermediate engine rpm's, without further warning lights so far.
Previous discussions on this site have noted a problem with rust particles forming, likely in the fuel tank, becoming dislodged, and migrating to the fuel injectors. This blocked their screens, disrupted fuel flow, and generated symptoms like those noted above.
Questions:
1) What other problems give similar symptoms?
2) How long does it take, approximately, and how much engine disassembly is requried, to clean injector screens (and replace the fuel filter)?
3) If there is rust forming in the fuel tank, does the injector problem simply reoccur regularly, till the tank is cleaned out, presumably followed by coating the tank with rust preventing polymer?
Maurice
. Rusty tanks and fuel systems are usually the result of long term storage. The best way to avoid this is to regularly fill the tank and use the gas. It's been my experience that fuel pumps will typically no longer work after such an event, & that requires tank removal to replace. While replacing the pump, one can't help but notice the condition of these internal parts (as shown on page 2 of this thread:
. Maybe the oil change guys did something, maybe not. Seems to me more likely a coincidence (but who knows). Tim
