My 2nd Toyota Van in 30 years. LOVE THIS ENGINE!!!!!!!!
This one is a '93 Previa leaking coolant on ground- looked under car and see leaks from radiator.
Reservoir Cap also needs replacing (rubber gasket crumbled)
Hubby says try the POUR IN fill leak/gap repair product- my gut says NO- don't do it- REPLACE.
So ...
OEM Radiator is $460 from dealer
Online Radiators ( non-Toyota( from $99 +) are they as good????? Any recommendations?
or should I try and pull from Junkyard?
also does anyone have an online tutorial. I do not have a service manual.
I PROUDLY have done alot of my own service work- THANKS to folks sharing incredible tutorials online. THANK YOU!!
so .... ANY ADVICE would be appreciated!!!!
SPECS
Deluxe All-Trac Passenger Minivan (2.4L 4-cyl. AWD 4-speed Automatic)
wooohoooo
So do I need to replace any of the oil that was dripping out when I removed them from radiator?
