The heater control in the dash is known for breaking in our vans. it cracks and then flexes rather than moving the cables fully as it should. If you take out the heater control you should be able to repair/reinforce it with a few paperclips and some JB Weld at the broken areas. I think Toyota still sells these for around 100.00 but the liquid weld method is a stronger and better fix.
