Results 1 to 5 of 5
Thread: leaky bellhousing / Clutch, Bearing, Seals Replaced
    1988 4WD LE 5 spd mnl
    Oct 2013
    so cal
    I didn't know if I should start a new thread or try to revive this one : http://www.toyotavantech.com/forum/showthread.php?2819-4WD-manual-new-to-the-forum
    Recently my leaky trans got pushed to the front of my priority list. My neighbors complaining about the leaks on the street, and the clutch slightly starting to slip caused me to want to get it done asap. It was also noisy at fwy speeds in 5th gear, like the "whirring" sound Thurston describes in thread above, or a speeding RC car down the street.
    So I cracked open and dropped the trans/bell housing and here's what it looked like-
    Attachment 3160
    Took me several hours to clean out all the gunk and grime and oil! man! So long story short, I believe my main leak was my input shaft seal. It wasn't even seated. The rear main seal looked nice and dry, but I replaced it anyway, along with the throw-out bearing, new input shaft seal, pressure plate, resurfaced flywheel, replaced clutch disc. ( I can post more on this process if any other newbs like me, have questions) Clutch disc wasn't OEM from Toyota like everything else. It was Aisin part # DT-036. I was told by a local parts place this disc would fit, even though cross ref the Toy part # didn't exactly jive. I was told to not worry. Ooook. So after getting it all cleaned up nice and buttoned back together there are a few things still going on I'm noticing.
    1- Still getting the "wirring" noise. Only when on gas accelerating. Which now I think I understand from thread above, may be my input shaft bearing. Ug, I was just in there!
    2- Sitting at idle I'm getting a noise, almost like the noise you get when a power steering pump is going out, that goes away when I push clutch in. Could this be blamed also on the bearing? Or blamed on the clutch model I was sold?
    3- Shifting isn't very smooth & difficult to get into reverse at times.
    4- Van tends to kind lurch or "clunk" into gear as I accelerate and shift up into gears down the road. 1st, 2nd & 3rd gear mostly. This is not that bad, I just imagined it would be nice and buttery after all new parts and having a dry bell housing etc...
    Any thoughts on my issues? Could the "wirring" sound at fwy speeds in 5th gear be from a drive shaft bearing not the input? Was hoping it could be this instead cause it would be a lot easier to do...I think...
    Thanks for the help and time...and merry xmas by the way.
    Re: leaky bellhousing / Clutch, Bearing, Seals Replaced
    Bad input shaft bearings tend to be quiet when in 4th gear (1:1 ratio with engine RPMs), but make noise in other gears. If yours behaves like this then it's almost certainly an input shaft bearing creating the noise. The hard shifting issue sounds like the clutch might be out of adjustment (not disengaging all the way). Make sure the clutch is bled completely and then check the adjustment. The service manual explains how to adjust...........just follow the directions in the clutch section. Good luck. Tim
    Oct 2013
    so cal
    Followed instruction back in December as Tim mentioned and found that everything seemed to be where it needed to be. Been so stinkin' busy, but I finally may have some down time soon to follow up on these issues on my van. I'm still having the hard shifting [...]
    I plan in the next month or two get whats needed to re open everything up to attempt an input shaft bearing fix.... (still have a pretty bad, jumpy low whining at low speeds, and high "whirring" at fwy speeds tranny noise)..Any special instruction is much appreciated...
  4. 04-28-2016, 02:59 AM
  5. #4
    Oct 2013
    so cal
    Thanks Tim.(Glad your busy currently with work..Hiring? ha ) After re reading my first post I realized I was kind of repeating myself, sorry. I'm not looking forward to possibly doing work over again no, but it's all needing to come down again to dig into trans to replace input shaft bearing and what not.
  6. 04-28-2016, 12:16 PM
    Reason
    no longer relevent to this thread; copied to a relevant thread
  7. #5
    1988 TV Panel 4x4 5-Speed 1989 TV LE, Dual Sunroof, 2WD Automatic
    Jul 2018
    NC
    I'm needing to do this job very soon.
    Just curious to see how yours came to a conclusion. I realize it's been a few years back. But any final thoughts would be helpful. Thanks.
