Ok , I have searched and searched and still for the life of me can't verify the identity of the sensors or switches located on the water outlet housing . One has a green plug and the other a brown plug . Can anyone identify these and give part numbers ? I have read through several post and seen several pics and they give different names !!!! I also need connectors for those of anyone can point me in the right direction . Thanks !!!!
I believe Original is correct. You can easily test this by turning the key to "run", then try touching the wires together. If it's for the overflow bottle float switch, the radiator light on your dash should blink on/off when you make/break connection.................assuming the bulb is still there and not burned out. Tim
