Re: Intermittent Starting Problems & Check Engine Light!!! '91 Previa LE AWD
Let the updates continue...
So after installing new contacts (which were very worn after a year of hard starts) the starting problem still exists. The next attempted fix will be replacing the entire distributor assembly (as per Tim's pick up coil suggestion), after the long weekend (up here in Canada).
Will continue to post, probably on Wednesday...
Ari
