Results 1 to 5 of 5
Thread: What parts are a total PITA to find? 95 S/C AWD
    1995 Previa Alltrac S/C
    May 2015
    Golden
    Question What parts are a total PITA to find? 95 S/C AWD
    So I just found out my local scrapyard have got in a mostly intact matching van. Not sure what is broken or taken yet though.
    From experience does anyone have any ideas for parts that regularly fail and are very hard to source these days?
    I'll be grabbing the external fuse box if its not too corroded and the parts I actually need now, but was wondering what else should I pick up? My SADS is good.
    Cheers,
    Jane
    1993 Previa 2WD
    Sep 2012
    Dallas, TX
    Re: What parts are a total PITA to find? 95 S/C AWD
    steering column trim covers... the plastic was crispy to begin with and then uncaring idiots at junk yards destroy good ones while going for their precious parts
    92 previa
    Louisiana
    Fuel rail with injectors and pressure valve,head, distributor, coil, cold start sensor, VSS, air intake tube, relays, etc?
    Jan 2013
    Mountains
    Hi Jane! Climbing much?
    96 Previa SC 2wd
    Aug 2013
    South Florida
    Quote Originally Posted by Irish_Jane View Post
    Cheers,
    Jane
    Ive been looking for the roof trims, particularly the passenger front. Mine are the late model LE version w/sunroof and most junk yards only have the standard trims.
