JPERL
so I can get a picture of what happened.
Did you bolt the converter to the flex plate and try to install the engine with torque converter attached to the engine? If so the correct procedure is to install the converter in the transmission and then align the converter bolt holes to the flex plate bolt holes and install the bolts.
Are you saying the flex plate (fly wheel )is damaged. Its hard to tell from the description. If you take the converter out of the equation is the transmission damaged at all? I would think the damage you mention is isolated to the converter but difficult to say. Any pictures?
