I believe I have bad front passenger side wheel bearings. There is an audible growl which increases with speed. It doesn't matter if I am stepping on the gas or coasting, have hubs locked or unlocked, or if I am on pavement or dirt. There is no play in the wheel and it spins easily. When I swerve to toward the passenger side the growl, and associated low/mid-frequency vibration goes away. Swerving toward the driver side increases the growl slightly.
Today I pulled the bearings out and they still look fine to me. The races look fine too. I repacked these bearings a few thousand miles ago / 1-2 years ago. I have convinced myself that the bearings are the cause of the annoying growl. The grease around the inner bearing was black, while the grease around the outer bearing was blue (I used blue grease to repack both bearings).
MOD EDIT — the following part numbers are for 4WD Vans
Are the inexpensive bearings at rockauto okay? The Toyota bearings are MUCH more expensive:
Inner 90366-50011 $59.71 @ TPD
Outer 90368-45087 $36.02 @ TPD
The bearings I took out of my hub are not the same type:
Outer bearing is labeled MEXICO HT1 LM102949/O
Inner bearing is labeled JAPAN KOYO HI-CAP TRIDO802A
END EDIT
When I look up Toyota part numbers at ToyoDIY.com I do not see the races. Do Toyota roller bearings come with races? To get the races out of the hub do you just tap them out?
