WTF did I do???? Someone please, The car would start just fine after replacing the fusible links, now that I tried replacing the grounds wire again theres absolutely nothing. I cleaned the bolts, and made sure everything was tight. I did nothing to the positive terminal. Im so confused.. I had so much progress for it all to be swept away. I really need someones help here, I wish I could just afford a mechanic at this point but no sir. I have to magically get this started tonight or I loose my job. Gahh Imma keep working on it till I fall asleep in the engine. Hopefully something will surface.
