Results 1 to 4 of 4
Thread: 1992 Previa Heater Control Valve?
    1992 Previa
    Nov 2017
    USA
    The heat on the wife's 1992 Previa will not totally shut off when the dash leaver is pushed to the full blue/cool range. It mostly does, but on hot days you can notice heat still coming from the vents.
    Question...is this a likely failing heater control valve?
    1992 Previa
    Nov 2017
    USA
    Re: 1992 Previa Heater Control Valve?
    Okay...did some deeper looking...and noticed the cable was simply held in by a clip, so I popped it off, and made an adjustment. In removing the cable, I saw that there was some binding to the valve and cable, so I lubed them. Might have solved the problem, but if not, I suspect the seal on the valve is bad...maybe if I am lucky there is not a seal : )
    Mar 2013
    SL,UT
    Here are some pics to accompany this thread for others with this problem. It is a common one. Often the culprit is the clamp which holds the cable at the valve has come unclamped and the cable has shifted so the lever on the dash cannot close the valve fully.
    The pic below shows the valve in the fully closed position with the rotating lever on top of the valve butted up tight against the tab on the mounting bracket. Note on the left of the pic the clamp holding the cable has popped up allowing the cable to move.
    Here's the clamp pushed down how it should be and the valve in the fully open position.
    After you've adjusted the cable and clamp and tested the dashboard lever to check that the valve fully opens and closes correctly, give the clamp a squeeze with pliers where it folds under its bracket to help it not come undone again.
    1992 Previa AT LE
    Connecticut
    There is a seal of sorts on the valve - a plastic sleeve inside between the housing and the part that rotates. I cut mine apart some time ago when mine stopped working properly. I had to replace mine to solve the problem.
