Results 1 to 15 of 15
Thread: 4WD RADIATOR MOUNTS
    wherethevanisrare. FL
    4WD RADIATOR MOUNTS
    So I took the RWD radiator out, and I'm about to install the 4WD rad. in there when I realize something's missin'. there is nothing to receive the lower mounts of the 4wd radiator. Who ever put in the wrong radiator made room by taking out the receiving brackets for the 4x radiator and I have no idea what they look like!
    What is missing?
    Anyone has pics of bottom mounts or bracket to mount the 4WD rad. on?
    LG.
    Van Addict boogieman's Avatar
    abq, nm
    Re: 4WD RADIATOR MOUNTS
    Awesome! I love this forum!
    Then the next question is: Where do they mount? And the next one is: are they extras and avalable?
    Thanks boogieman.
    LG.
    abq, nm
    they're out of my 89 which has a 2wd radiator in it right now..im holding on to them for now. they could easily be fabbed, the single slot holds one of those rubber standoffs with 2 8mm studs....the other two bolt to the body, you should have two captive nuts on each side...
    I can only see this one in the area but its all alone!
    LG.
    abq, nm
    lower..these cradle the bottom of the radiator
    LG.
    Van Enthusiast VanCo's Avatar
    Salt Lake City
    Yes.
    Sorry about the picture size. Hopefully you can get the idea.
    Thanks VanCo. I have to go by pictures only, as the van is a 3hrs drive away. Lucky enough I shot 100's of them last week as I did a complete front end suspension replacement. Knocked a ton of rust off with a needle hammer and Ospho treated every thing I could reach. I was waiting for an order of new bushings so I still have to finish the sway bar. Every piece of rubber is getting replaced. Every thing is bolted on with Anti-seize. I dont want to hear a squeak from there when I'm done and its going to feel like butter.
    I can fab. pretty much anything here in my shop. It just has to drop in and fit when I get there. It would help if I could get some dimensions from one of you guys.
    Thanks again.
    LG.
    Salt Lake City
    I just found two I didn't know I had. They are yours for the cost of a six pack and shipping.
    I could also give you the specs if you wanted to fab some.
    You are awesome my friend! What's your favorite Brew? I'll double it as a donation to TVT , how about that?
    LG.
    Salt Lake City
    My go-to beer is Sierra Nevada pale ale.
    Sounds good. I'll PM you.
    Edit:
    Tried to PM you and I got a message saying your PM inbox is full.
    Good beer choice! Cleared my PM box. It fills up quick when chasing parts.
    LG.
    COOL, I just PayPal-ed my first Beercoins And a little in TVT's way.
    My van is getting the Bits
    LG.
    THANK YOU !!!
