Results 1 to 5 of 5
Thread: Clutch release cylinder rubber line, Manual 4x4
    87 VW Vanagon Syncro
    Apr 2017
    Boise
    My repair manual only gives info at the master and the release cylinder, but no part number info on the lines. I have not been able to find any information on the soft line to the clutch release cylinder. It looks like it may take just a regular brake line, but I can't find info anywhere online or here at TVT. Anyway, this bulge looks not great, although clutch is working fine but need to fix. Anybody have info on this part number, and/or info on the other parts/info/forumthreads directly related or connected to the line?
    Re: Clutch release cylinder rubber line, Manual 4x4
    In the EPC, I'm seeing a "HOSE, CLUTCH, NO.1" with the lines on either side called "TUBE, CLUTCH MASTER CYLINDER TO FLEXIBLE HOSE" and "TUBE, CLUTCH RELEASE CYLINDER TO FLEXIBLE HOSE". And I don't like that bulge either!
    Looks like the part number was 31418-28020 for all Vans, all years; this was superceded (new part number 90931-01021).
    Apr 2017
    Boise
    Awesome Gwen, thanks! What is the EPC???
    Quote Originally Posted by Fiftythree View Post
    What is the EPC???
    Electronic Parts Catalog. It's what the Toyota parts departments use to find part numbers, and (unfortunately for all of us) copyright by Toyota, so not readily accessible.
    If you have a local hydraulic hose shop they can make these for you. I've done this with brake and clutch lines on a few vehicles.
