Quote Originally Posted by rowemjr View Post
I'm currently trying to replace my alternator and I have all the bolts removed except for the bottom 14mm pivot bolt. Am I understanding correctly that this bolt is not threaded, it just pushes through? I have removed the nut on the backside but cannot remove the bolt it just turn and turns. If it is just supposed to push out any tricks for doing this? Thanks
Actually, if memory serves me I had to lefty loosey mine to get it out. Not threaded necessarily, but it helped.
Take a small rubber mallet and tap it out if you can finagle one down in there.
