Page 12 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 221 to 240 of 343
  1. #221
    wherethevanisrare. FL
    LG.
  2. #222
    '88 4x4 5 speed manual
    Dec 2018
    ME
    someday I will learn to read a wiring diagram - in the meantime I keep trying to back my way into the rogue wires.
    Any ideas on where this one goes?
    Seems like it would connect near the radiator cap somewhere. Got a sketchy wire there already but no room for a 3rd connection that I can see.
    BONUS CLUE - my radiator light is always on.
  3. #223
    There’s a thread that outlines all the ports around the filler neck but I’m not able to locate it at this time, as for your radiator light “staying on” your low on coolant, loosing coolant somewhere or your overflow bottle sensor has gone out??
    Here’s a thread on “radiator overflow bottle sensor”
    https://www.toyotavantech.com/forum/...ht=Filler+neck
    Hope this helps, this may not be the problem but it’s an excellent read
  4. #224
    Dec 2018
    ME
    on it - not leaking any coolant but thanks for the link JDM, I love going deep on these issues regardless.
  5. #225
    Van Addict boogieman's Avatar
    abq, nm
    sketchy wire is to brown thermal time switch, cold start injector...youre in maine? fix it(btw that sensor is expensive)....fix the other green wiring too as thats the sensor for ecu to read coolant temp and adjust fuel....the lost wire should be grounded, it was for a hot soak fuel pressure bump up for 2 mins? but its better to just ground it so it bumps up every start.
  6. #226
    Dec 2018
    ME
    thank you!
  7. #227
    1987 blue auto 4x4
    Apr 2019
    Dallas, TX
    I'm assuming this one is California's fault, but I couldn't find it in this thread or any others google gave me:
    to help triangulate - that's between the airbox, battery, and exhaust, runs up and taped to the O2 sensor wire.
  8. #228
    That's your Throttle Position Sensor harness connection. On the back side of the throttle body there's a black plastic box. The connector in your picture should be plugged into that.
    Here's a thread that features the throttle body and the TPS:
    https://www.toyotavantech.com/forum/...-Throttle-Body
  9. #229
    1987 blue auto 4x4
    Apr 2019
    Dallas, TX
    Thanks Tim, I never would have caught that the way it was taped so far down to the sensor wires. I’m wondering if that was responsible for the way she’s always bogging down after puddles.
  10. #230
    88 4wd
    Apr 2017
    Oakland
    OK - here's one I could use some help with compatibility on ... I'm looking for part #22230-73011 Auxiliary Air Valve which is NLA. (For '85-'88)
    HOWEVER - the part #22230-73010 Auxiliary Air Valve for an '84-'86 is possibly available (and also one that I can probably go get from a junkyard)
    It says that #22230-73010 has been REPLACED by #22230-73011... Does this mean I can use 73010 in 73011 applications? My concern is the 2.0 Vs 2.2 L engines, but maybe it's pretty much just the same valve? I don't really want to pull my manifold if it won't fit
    Name:  Screen Shot 2019-06-11 at 9.17.31 AM.jpg
    Name:  Screen Shot 2019-06-11 at 9.17.37 AM.jpg
    Links if that his helpful:
    73010: https://www.toyotapartsdeal.com/oem/...0=YR22LG-MDEA)
    73011: https://www.toyotapartsdeal.com/oem/...230-73011.html
  11. #231
    If one replaces the other then I'd have to say either one would work. I have been looking for one of these for a while with zero success. At one time there were at least 2 or 3 aftermarket manufacturers that made these, but none of those are out there any more either. If you find a source, please post as I'd be willing to pay up to $300 for a new one. Tim
  12. #232
    1986 LE
    Aug 2017
    Florida
    I believe Nissan makes it. There are many version but all look the same. Just make sure the mount is like ours. Rock Auto has some of these you may want to check out
    I don't think Rock Auto has these (at least not one made to fit the van). They used to, but now under that title they only show Idle-up Diaphragms. If anybody finds one that is compatible and will interchange (without reinventing the wheel), please post a link. Thank you. Tim
  14. #234
    1987 toyota van le
    Jul 2019
    nj
    RUSTED PIECE UNDER CAR
    OK thank you for all the help so far. i just looked under the car and saw this that freaked me out. what is the name of this part
    and what's my issue here? what should i do? call it quits on the car or is it and ok fix? the car turns on and sound good so far and drives well.
  15. #235
    I don't know an exact name for that part but it is definitely cause for concern. It is a structural crossmember crucial to the strength and integrity of the rear suspension. Also, in the upper left of the picture it appears one of the floor crossmembers has rusted through as well. These are unibody vehicles and every component is important to the strength and safety of the overall structure. Anything is repairable if you are willing to spend the time and/or money to male it happen. I would definitely have someone qualified take a look at that if it's outside of your comfort or skills.
  16. #236
    1987 toyota van le
    Jul 2019
    nj
    thanks for the response thats what i figured to if anyone knows the name please let me know so i an look for the part
  17. #237
    1987 toyota van le
    Jul 2019
    nj
    I believe this is how it should look like. it probably part of the axel assembly but just want to find name im searching and searching. so ican get a guessistmate on price and see if a junk yard might have it
  18. #238
    Van Enthusiast VanCo's Avatar
    Salt Lake City
    That's funny, that screenshot is from my van. I'm glad the video has been useful.
    Anyhow, there really isn't a name, or a "part" that can be purchased. That is a structural (welded in) part of the unibody used to attached the upper 4 link arms.
    To fix it, a fabricator would need to cut out the old piece, fabricate a replacement, and weld it in.
    I'm guessing if that has rusted that bad it may not be something that can be repaired easily. I say that because where the fabricator would attach a fabricated 4 link mount would need to be structurally sound and rust free for welding
  19. #239
    1987 toyota van le
    Jul 2019
    nj
    yeah i saw your video and grab that shot lol. thank you. im looking all online and i totally understand what your saying. im still fixing other things in the car with my son brakes, rims, rotors. i do want to fix this. its all aslow process. i got under to see the the rust and yeah its pretty rusted i can still crab some metal pieces from end to end. i think welding would be possible. i would have to my mechanic to get some idea. i think everyone thinks im crazy but i dont want to give up on the car. any other pointers or ideas would be much appreciated!
  20. #240
    Salt Lake City
    I don't think you're crazy. I have about $10k in engine, turbo and overlanding gear on one of mine, and yet you can put your finger through most of the body panels. Wait, maybe we're both crazy?
