Wondered if anyone knew of any other springs that can be swapped into a 2WD van? My rears are a bit saggy, and the drivers side leans a bit as the gas tank empties. Its caused excessive wear on my drivers side tires, and I'd like to just replace them before I go in for a front end alignment.
I've looked at local wreckers inventory, but the closest Canadian recycler with springs are on the East Coast, and they're in bad condition.
Does anyone know the specs of the springs? Even if I could put in something close enough to stock, then I could level off the fronts with my torsion bars. Worst case if I can't find any springs, I may have to get a shop to make a set for me...
Thanks in advance!
