Re: Wheel noise?
Well now, got the parts in the mail.
Turns out after seeing the spacers and snap ring with my own eyes that I actually removed these when I did the hub overhaul. You see, there was a 3 week lapse in the doing the two sides, the first side I did slowly and it had the snap ring/spacer, and the second side (drivers side) I was sorta rushed. My mom was having all my grandparents over because we weren't going to be out there again before leaving for Maine, and I was trying to get the job done before lunch, kept pushing back the time, didn't want to do anything wrong but in the end I removed this snap ring/spacer thinking it was part of the Auto 4WD hub brake assembly.
So....now I ended up spending $$ on the parts AND the pliers (the wrong ones, they worked but it was a pain) and I never should have had to do it!
I kept the parts I removed from the van originally, so I had the original spacer, put that on, wrestled with the snap ring/pliers (ended using a screwdriver too to get it on) and the axel is now tight and within spec clearance wise.
I was surprised actually at how much the axle could move in/out of the hub without the snap ring/spacer.
I took a little drive with the fam for some dinner, we didn't hear any sounds, but then again the new sound was intermittent so I won't believe its all fixed until I do some real driving, which will happen Thursday, 500 miles to our new little farm in Maine.........
mark
