Page 14 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 261 to 280 of 343
  1. #261
    wherethevanisrare. FL
    And please post back to confirm : Worky.. No worky
    LG.
  2. #262
    NA
    NA
    Have a small leak from this hose connection
    Not sure what this connection is, but I have a small leak and would like to know how to properly fix it. Photo of it attached
    Also, is there a good diagram image that lists all the parts/connections on the engine?
  3. #263
    Re: Have a small leak from this hose connection
    Power steering hose.
    It is also the reason for your alternator failure.
    The search function is your friend here.
  4. #264
    86 toyota van LE
    Jan 2017
    santa cruz
    86 van overdrive solenoid
    Anyone have the part number? Thanks.
  5. #265
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Re: 86 van overdrive solenoid
    EDIT: Both are NLA
    85420-28020
    this the solenoid mounted externally on the left side if I understand correctly
    And this as well its the overdrive relay that is mounted under the console/shifter
    89531-28010
  6. #266
    86 toyota van LE
    Jan 2017
    santa cruz
    Excellent! Thank you
  7. #267
    86 toyota van LE
    Jan 2017
    santa cruz
    Looks like it’s a “discontinued part” 😤.
  8. #268
    1987 Toyota 4x4 le van
    Dec 2019
    Kona
    Locate efi fuse
    Which fuse is the efi fuse? I want to clear my codes and was directed to the fuse box and then to remove the efi fuse for 10 seconds. Only problem is my 1987 doesn't have a designated efi fuse. So which fuse do I pull? (Ign/eng/ecu???) Please help Zman.
  9. #269
    HERE is the thread with the link to the article that shows the fuse box diagram; the 15A fuse in the separate portion on the right of the block is the EFI fuse.
  10. #270
    1987 Toyota Van le 4x4
    Mar 2020
    Oregon
    Lightbulb Re: The WHAT-IS-THIS-PART and WHAT'S-THE-PART-NUMBER Thread for US Toyota Vans 1984-1
    Hey looking to any ideas to what part this is or a part number.
    this part came directly of the fuel tank it is a part of the main line,
    I thought it was a fuel filter and removed it to be replaced it got broken in the time after.
    I went to Napa and other places and no one knows what it is.
    it came of the stock fuel lines, and unfortunately has no part number
    i have a 1987 Toyota Van with a manual transmission and 4x4
    Thank you for any support an advice!
  11. #271
    It's Toyota part #90917-10020 and is discussed in more detail starting on post #13 of THIS THREAD
  12. #272
    Mar 2020
    Oregon
    Smile Re: The WHAT-IS-THIS-PART and WHAT'S-THE-PART-NUMBER Thread for US Toyota Vans 1984-1
    thank you !
  13. #273
    '88 2WD LE
    Feb 2013
    United States
    Hello,
    Is the part number known for the Mud Flap Bolts? I have an 88 LE.
    I have some flaps, but no bolts. Didn't know if anyone had any expertise.
    THANK YOU!
  14. #274
    1987 4WD 5spd- 270k
    Jun 2020
    Hello fellars, trying to figure out what is this little guy. Any help is highly appreciated.
  15. #275
    It's called "FILTER, GAS, NO.1" and it's Toyota part #90917-11022.
    https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
  16. #276
    1987 4WD 5spd- 270k
    Jun 2020
    Thanks a lot, Tim!
    Ps I am recoring the radiator I salvaged with John, yuba city. 4 row high efficiency.
  17. #277
    '86 Toy Van
    Dec 2017
    Utah
    Circled missing bracket. 86 manual G53.
    https://www.amayama.com/en/part/toyota/1232613010
    This page for item 1232613010 shows schematics labeling the brackets as both as the SAME number 12322.
    Found this which might have a part
    https://oemparts.stonemttoyota.com/p...232613010.html
    But sadly the store here is sure that almost every bracket will fit every year van and every transmission type, which can't be true, so I'm not able to figure out what part is real.
    Anyone have these part numbers for an 86 manual?
    Also the grommet in the shift linkage hole if you have it!
  18. #278
    vancouver canada
    What's this connector!?
    Any idea where this connector attaches?
    The bridle leads it to be a few inches from the radiator cap, at top of the engine.
    .... Also, what is its function?.... And is it even necessary?... The wire itself is fried and detached so I kinda hope I don't even need it!
    ... The connector itself it's a boat 5/8 inch diameter.
    .... Any assistance is greatly appreciated, thank you.
    ...edit... But wait,, there's more! Just one, thankfully,, the blue one is located on the passenger side of the head,, a ~4" lead, between spark plug 3 and 4,,,~3/4" size. Any ideas? <;~o
Size:  83.8 KBName:  20200806_151552.jpg
  19. #279
    vancouver canada
    Re: What's this connector!?
    Anyone?
  20. #280
    1989 Master Ace Surf
    Sep 2020
    Seattle WA
    Does anyone know what the OEM part number is for the PCV valve for the 3Y engine? Not sure if it's different between the JDM and USDM vans but I have an '89 Master Ace which appears to be mechanically most similar to the '85 Van. Also, is there a recommendation on which brands to avoid? I've learned the hard way that some parts are not built like the others...
