Results 1 to 20 of 37
Thread: Sensors to overdrive
Hybrid View
    Re: Sensors to overdrive
    Quote Originally Posted by Javier View Post
    Does anyone know if the solenoid for a 2wd and 4wd are compatible or the same thing? I am looking at one on ebay right now since mine is non functional. I have a 1989 LE automatic 4x4Thanks!
    If your solenoid is getting power and it's not shifting into OD, then (and only then) should it be replaced. And yes, these are the same on all van transmissions. Volvo also used this same solenoid with the only difference being the single wire terminal end (a review of this thread should give details and part numbers). Tim
    1988 toyota van 2wd automatic 1989 toyota van le 4x4 automatic
    Jan 2017
    Pico Rivera
    Thanks for the support, I have checked all the possible causes and the solenoid is faulty.
    Jan 2017
    Pico Rivera
    I just replaced the od solenoid with a brand new one I ordered from Ebay $+180 delivered, works like a charm and shifts like a dream
    1986 Toyota Van 2wd
    Jun 2020
    LBC,CA
    Awesome Javi!
    Not to break your heart but this is an option as well.
    https://www.ebay.com/itm/New-A-T-Ove...AAAOSw1V9ePQt4
    Jan 2017
    Pico Rivera
    Great!! I was told that wouldn't work ooh well it's good to know for future references better late than never
    Quote Originally Posted by Diy2k View Post
    Awesome Javi!
    FYI, I got that one and have put approx 80k miles on it. It has leaked from day 1. It doesn't leak a lot, just enough to make my van undercarriage a bit nasty from the mixture of dust and ATF. If I had to guess, I'd say it leaks about 1 cup every 5k miles. It has functioned well, but I despise leaks. if I had to do it again I'd probably just pay the $180 or whatever for a quality part. Tim
    Jan 2017
    Pico Rivera
    Update to now 7/13 /21 and my od solenoid is leaking the one I paid $180 for wow wtf. 🤬 I suppose I will try the volvo one. Seller will not claim warranty on part.
    1985 automatic
    Jan 2021
    Victoria, B.C. Canada
    To replace my non-functioning overdrive solenoid, I got one of those blanking plates off Amazon or Ebay that keeps the overdrive engaged all the time. It leaked when I first installed it. It turned out that the supplied o-ring was too thin and barely protruded above its groove. I replaced it with a thicker o-ring and it's been fine since.
