- 0
Manual 4x4 transmission $225
For sale is the manual transmission member https://www.toyotavantech.com/forum/...p?4494-jdeight sold last year. While neither I nor he knew the history of it, it shifts through all gears by hand with no crunching. The level of grime and corrosion would imply a low mileage unit. I already sold the bellhousing and bolts to Jdm vanman and am keeping the xfer case for my 5 speed previa. Ships from Littleton Colorado.
- 0
Re: Manual 4x4 transmission $225
what else would I need including this to swap my auto in for this? Will the auto bell housing work? I know I would need the shifter.
