Page 15 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 281 to 300 of 343
  1. #281
    Quote Originally Posted by flinters17 View Post
    Does anyone know what the OEM part number is for the PCV valve for the 3Y engine? Not sure if it's different between the JDM and USDM vans but I have an '89 Master Ace which appears to be mechanically most similar to the '85 Van. Also, is there a recommendation on which brands to avoid? I've learned the hard way that some parts are not built like the others...
    Looks like the PVC valve is the same for both 3Y and 4Y part number 12204-71010 replaced by 12204-15030, double check for accuracy. this is a common part used in numerous vehicles from 84'-93' such as Celica, Corolla, Tercel and Vans
    Forum Newbie toyotatimemachine's Avatar
    !984, le 2wd, auto, sunroof, silver, with a blue interior
    B.C
    What the heck is this and will fixing it sort out the stumble in my idle..vacuum-leak
    Hello
    I found a doohickey hanging off the top of the motor towards the Mack of views from the drivers side hatch. It has 3 vacuum lines attached a broken plastic screw and a spring fell out the bottom.
    any ideas? I’ll try to attack a pic or two.
  3. #283
    B.C
    Exclamation Re: What the heck is this and will fixing it sort out the stumble in my idle..vacuum-
    Should mention
    1987 4wd 5 speed
  4. #284
    1987 Toyota Van
    Aug 2020
    Seattle, WA USA
    Maybe more of a question of WHY-IS-THIS and WHAT-TO-LOOK-FOR-WHILE-I-CAN:
    Sometime in the vans history, the back firewall was chopped into to gain access to the back of the engine. After removing the back heater vent, discovered a poor attempt at a fiberglass repair and finally discovered where my exhaust fumes have been seeping in
    Before I weld it back, wondering if there's a good reason to keep a removable panel here instead of patching it up completely? I assume it must of made some PIA job easier in the past. Does this give access to "the hose of death" I've heard about or some transmission bolt that's otherwise impossible to reach?
    Wondering which parts (part#s) I may want to inspect or stock up on/replace while I still have easy access?
  5. #285
    Wow, that's a nasty looking hack job. There is a benefit to having some access here, but it's hard to imagine a cut like that helping much. If it were mine I'd weld/patch that, then maybe put a more reasonable access hole there if/when needed.
    Here's an example of a more reasonable way to get access to the "hose of death"
  6. #286
    1987 Toyota Van
    Aug 2020
    Seattle, WA USA
    Where is the hazard light relay located?
    Attached is photo of fuse panel but none of the relays seem to be labeled hazard.
    I'm on a road trip, got pulled over for no tail/break lights(solved) but learned in the process that hazards don't work. Fuse is fine, next guess is relay but forgot my manual at home.
  7. #287
    Oh oh thats not good, look at posting number 4 in this thread-
    https://www.toyotavantech.com/forum/...t=hazard+relay
    hope this helps
    87 toyota vanwagon
    Dec 2020
    LA
    Name:  Screenshot 2021-03-27 at 3.33.16 PM.jpg
    hi what is this component to the left of the battery ? I found the two nuts loose, tightened them up but would like to know what this is ? thanks
  9. #289
    87 toyota vanwagon
    Dec 2020
    LA
    Re: Anyone know what this is?
    would removing the "ballast" affect the handling of the van ? i have an 89 4x4 cargo van
    Interesting, I've only seen those in the 1st gen cargo vans (which also have rear coil springs rather than leaf springs).
    Ballast is as good a term as any; I forget the Toyota term. I removed mine.
    EDIT: Toyota calls it the Rear Floor Balancer.
  10. #290
    Quote Originally Posted by pigneguy View Post
    It's kind of hard to identify by that picture, but I believe that's a solenoid switch similar to this one: http://www.texasindustrialelectric.c...s_24812_01.asp. I'm guessing at some point a P.O. had a 2nd battery mounted somewhere and he was using that solenoid for a battery isolator. He probably took the battery out and disconnected the wires, but left the solenoid behind. Tim
  11. #291
    87 toyota vanwagon
    Dec 2020
    LA
    thanks Tim
  12. #292
    Not that I have noticed.
  13. #293
    87 toyota vanwagon
    Dec 2020
    LA
    good to know cos they weigh a ton, maybe get a fraction of a mile per gallon more
  14. #294
    Van Enthusiast 89van's Avatar
    Jul 2021
    Phoenix, AZ
    Curious if anyone knows the number for the shroud around the door lock on the interior (see picture) as my van seems to have that missing. Passenger's side preferred but if they're interchangeable that'd work too hopefully.
  15. #295
    There's just one part for both sides; they are interchangeable. Toyota part # 69751-20031; officially called FRONT DOOR LOCKING BUTTON COLLAR HOLDER
  16. #296
    You mean this?
  17. #297
    Jul 2021
    Phoenix, AZ
    Yep, thats it! Thanks. You guys know everything!
  18. #298
    Jul 2021
    Phoenix, AZ
    In addition, do you also know the part numbers for door locks for the sliding door exterior and the rear door? The sliding door is busted (everytime I shut the sliding door, the whole assembly pops out like its craving freedom!) and the rear door lock just doesn't turn; bent a copied key trying to open it! Gonna be stocking up on parts to order now that I'm doing some quality-of-life fixes to it... Once again thanks guys!
  19. #299
    Go to this site: https://www.toyodiy.com/parts/q.html (it can be helpful in finding/cross-referencing part numbers). I'll also email you information on how to get access to Toyota's break-downs.
  20. #300
    Jul 2021
    Phoenix, AZ
    Will do.
