Results 21 to 40 of 47
Thread: The WHAT-IS-THIS-PART and WHAT-IS-THE-PART-NUMBER Thread for Previas
    1993 Previa 2WD
    Sep 2012
    Dallas, TX
    Re: What component is this?
    for?
    Van Addict cvtroger's Avatar
    95 Previa LE S/C
    SF, Cali
    for?
    sorry, Nevermind.
    95 Previa LE S/C
    SF, Cali
    .waterpiping.jpgTrying to up the right diagrams for reference.
    94 Previa LE/SC 215,000 miles
    Apr 2016
    Kentucky
    Looking for two part numbers for...
    ...a 1994 sc previa.
    Oil Strainer gasket
    Oil level sensor gasket.
    Any help would be appreciated. Also, if there is a source for a parts manual for a 94 please let me know.
    thx in advance!
    tim
    1993 Previa 2WD
    Sep 2012
    Dallas, TX
    Re: Looking for two part numbers for...
    15147-76020
    90430-36005
    1993 Toyota Previa LE 2WD
    Jan 2018
    Minnesota, USA
    What is this dangling sensor mounted below front of engine
    I've got a 1993 Previa 2WD LE. After a week sitting in below 0 temps, the van showed erratic temp gauge swings from normal spot to just below red; the heat was intermittent although the temp gauge lowered to near normal when the heat did kick out. When I got home, the bottom coolant pipe was cool while the upper pipe was warm. Added some antifreeze too since the reservoir was on the low side. Decided to replace the thermostat, when down there I see this dangling connector -must have been tugged apart by hitting one of the many large twigs on the driveway.
    Anyhow, the van is operating normally, temp gauge excepted. Does anyone know what this sensor is and if so, could it be responsible for the up and down temp gauge or was that just a coincidence?
    Frank
    1993 Previa LE 2WD
    92 previa
    Louisiana
    Re: What is this dangling sensor mounted below front of engine
    Looks like an oil pressure sending unit
    Jan 2018
    Minnesota, USA
    Yes, I was thinking something like that given the oil all over the cable. Seems to have busted at the cable, so I'll have to rig something up. Thanks for the confirmation!
    1997 Toyota Previa
    Jul 2018
    Southern California
    Hello Friends,
    My name is Tony. I'm new here. I have been trying to buy this part here: I do not know the name - Images.jpg but I do not know the name of the part. Please help me if you know it. Thank you.
    Re: Do you know the name of this part
    Hi and welcome to TVT! . I believe that's "HOSE, AIR CLEANER, NO.1" Toyota part #17881-76070, but sadly it's discontinued and NLA. At this point your best bet would be checking with salvage yards. Tim
    1997 Toyota Previa
    Jul 2018
    Southern California
    Thank you so much for your help.
    92 Previa
    May 2019
    Pullman, Wa
    oil pressure sensor??
    made the mistake of trying to pull out of the parking lot a few months back with there was still snow.
    and scrapped my undercarriage. the results was this.
    95 Previa SC, RWD, Auto
    Feb 2019
    Columbus, IN
    Re: oil pressure sensor??
    Quote Originally Posted by pnwPrevia View Post
    Can you pick the part up and shoot a pic of it somewhere better? It could be sasquatch for all I can see in that pic.
    -Russell
    -95 Previa SC RWD
    92 Previa
    May 2019
    Pullman, Wa
    Quote Originally Posted by kamesama980 View Post
  15. #35
    Mar 2013
    SL,UT
    Re: The WHAT-IS-THIS-PART and WHAT-IS-THE-PART-NUMBER Thread for Previas
    I'm not 100% certain but I think that is the wire which goes to the oil pressure switch which illuminates the oil pressure light (oil can symbol) on the dashboard.
    Does your oil pressure light come on when you turn the ignition to the on position?
    Below is a pic of the oil pressure sensor in the bottom of the engine on my '91 5 speed. It has a single spade connector coming out of it, but this may have been broken off if you have lost the central plastic engine undercover (which is feeble, easily ripped off, and hard to find replacements at scrap yards).
    Sorry the photos are upside down - that's what happens when you're crawling around in the street during a SLC winter.
    The rubber cover is long gone on mine, and I improvised a "break away" connector (basically an additional spade connection with the spade shortened so that the male part barely engages the female) so that I didn't keep breaking the tab off the sensor every time I went through bushes.
    If your sensor is broken, many Toyotas use this same sensor and so they're readily available at scrap yards. Ask a Toyota dealer to do a cross reference for a more modern common car which uses the same sensor.
  16. #36
    1997 Previa DX S/C RWD
    Feb 2020
    San Francisco, CA USA
    What is this part?
    I have a ‘97 Previa DX SC RWD.
    I can’t find a vacuum switch on any of the parts diagrams. It is under the hood, mounted on the rear of the radiator. It is below the power steering reservoir, next to the fan. It is in front of the supercharger pulley and has 3-vacuum hoses and one electrical plug.
    The hose that is able to hold vacuum slowly bleeds off and I think it could be the source of my vacuum leak. Anyone know what it is?
  17. #37
    Feb 2020
    Re: What is this part?
    Quote Originally Posted by Jumbojoe55 View Post
    Manifold Injection Air Control Valve
    25740-76010
    Discontinued
  18. #38
    1992 Previa AT LE
    Connecticut
    See if you can figure out what it's connected to (and better still, what it actually does). Either way, go to a Toyota dealer parts desk with the part number and photo. My suspicion would be that there's more than one other part available that's functionally equivalent - since most of these things are a valve that turns on or off with the application of +12V. It's obsolescence is likely more about its Previa-specific mounting hardware, in which case you could source a replacement valve and swap the bracket or jury-rig something to hold it in place.
  19. #39
    1997 Toyota Previa AllTrac SC
    Mar 2019
    Knoxville, TN
    Van Fan Kyle's Avatar
    87 4WD LE Auto
    Dec 2016
    Chapel Hill
    Does anyone know the part number for the tensioner pulley for the supercharger belt?
    It’s small, about 2.5” OD, 7 grooves
    I can’t find them listed anywhere on the internet :(
    EDIT: found them (Idler Pulley no.2 16604a or 16604-76010) called SPRING (FOR IDLER PULLEY TENSION) even though there’s no spring involved.
