Personally, I would start with the T-Junction. It's easier to get at and 9.8 times out of 10 will solve the problem.
On my left hand drive van, it had the high idle issue; cleaned the T-junction and it went away immediately. Not even 6 months later, the high idle came back. Second time around I not only cleaned the T-junction but also installed a filter between the junction and the IAC. The filter should collect any black flakes and prevent the junction from clogging in the future.
I am currently overseas, but I am going to do the filter mod to my right hand drive as soon as I get back!
If cleaning the T-junction does not solve the problem, then the IAC is obviously the next suspect.
