Page 16 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 301 to 320 of 343
  1. #301
    1988 4x4 Van
    Feb 2022
    Golden, Colorado
    What hose is this?
    Hey all!
    Is anyone able to help me find where to get one of these, or a good alternative for this hose? #22230M on the diagram.
  2. #302
    wherethevanisrare. FL
    Re: What hose is this?
    http://www.sotond.com/Automotive-Rub...pl3009354.html try this contact them and ask for something of the same inside diameter and roughly the same radius and for the same application ( gasoline,vacuum, oil, coolant etc). You can cut some part of a longer, multiple bends, hose. for vacuum look at there flexible silicon. Whatever you chose, do not loose those OEM clamps and re-use them, they are there for a reason.
    LG.
  3. #303
    1988 4x4 Van
    Feb 2022
    Golden, Colorado
    Appreciate it! I’ll check that out
  4. #304
    FYI, those hoses are metric. SAE sizes will not fit well. I tried all different manor of alternatives when I did my head gasket a number of years ago before I finally went to the dealer who was still able to order them at that time. I believe they are 14mm but don't quote me on that. Same with the heater hoses on the vans. Your either trying to stretch 1/2" hose to fit or clamping down 5/8" and hoping it doesn't leak which doesn't work well in the tight confines of the intake plenum.
  5. #305
    1988 Toyota Van LE
    Mar 2022
    Palmdale,CA
    Any idea what this green object might be on my 1988 Toyota Van LE?
  6. #306
    Looks like a broken PCV valve, of the (incorrect) plastic variety.
  7. #307
    1986 Toyota Van
    Nov 2021
    Oregon
    I was wondering what this line is coming from my power steering pump. When I was reading in a thread I saw this like but couldn't tell if it was the same part or not https://www.rockauto.com/en/moreinfo...nid=549&jpid=4 The bends/hook ups on the one in the link seem a little different than the one in the picture. Thanks
  8. #308
    Quote Originally Posted by Temassi View Post
    That's the power steering pressure hose that goes from the pump to the steering rack. Assuming this is for the 86 listed in your profile, I would think this is more likely the appropriate hose. https://www.rockauto.com/en/moreinfo...279751&pt=7320
    Last edited by originalkwyjibo; 06-28-2022 at 11:29 PM. Reason: Stupid autocorrect
  9. #309
    1986 Toyota Van
    Nov 2021
    Oregon
    It is an '86. That looks exactly like the part that I need. Thanks a bunch, I really appreciate it!
  10. #310
    1986 Toyota Van
    Nov 2021
    Oregon
    I was wondering if anyone knew what this was. It's located at about the center of the front bumper, the wire going into the cab is disconnected. It looks like a little megaphone. I thought it was the horn, but I've been able to find that in a diagram and it doesn't look like this.
  11. #311
    That appears to be a left over speaker/siren from an aftermarket alarm system.
  12. #312
    1986 Toyota Van
    Nov 2021
    Oregon
    Oh ok. That makes sense as to why I couldn't find anything in the books on what it was. It's just sitting pretty perfect in what looks like a spot made for it so I just wanted to double check.
  13. #313
    86 Van LE
    May 2022
    Netherlands
    This valve/actuator was dangling to the back of my engine, does anyone know sure where it should be mounted?
    The vacuum hoses are so long, I have no idea where to look.
    I think it is valve nr 2 on the diagram
    in my repair manual, i think it is mentioned as a vacuum switching valve, it is listed as part of the air conditioning system, but it does not mention where the part is supposed to be mounted.
  14. #314
    There's a hole on the side of the engine block behind the oil filter. Here's a picture of one mounted:
    It's your "pressure up" vsv. One hose should connect to the manifold via a little black filter device and the other hose should go to your fuel pressure regulator (other side rear of engine). Tim
  15. #315
    86 Van LE
    May 2022
    Netherlands
    Thanks a bunch!
    I put it back where it belongs. Judging by the amount of grime and rust covering that hole, it had not been there for a long long time.
  16. #316
    Van Fan alexpski's Avatar
    PAST: ‘89 Van and a ‘92 Previa. PRESENT: ‘85 Van
    Nov 2017
    Brockport NY
    Help! What is this part?
    Going bonkers! Looked at a ton of part lists and drawings trying to find this part! My eyeballs hurt! Anyone know a part number or what its called?? ('85 LE)
    Some weather stripping that runs along the outside of the window…
  17. #317
    Van Enthusiast 89van's Avatar
    Jul 2021
    Phoenix, AZ
    Re: Help! What is this part?
    Quote Originally Posted by alexpski View Post
    I believe that is "WEATHERSTRIP, FRONT DOOR GLASS, OUTER" part # 68160-87001. From my quick glances online, looks NLA as usual but it doesn't hurt to call around to double-check
  18. #318
    Nov 2017
    Brockport NY
    Help ID this part
    Can anyone tell me that the green sensor is below the temp sensor?
    Temp sensor is circled in this pic.
  19. #319
    86 Van LE
    May 2022
    Netherlands
    Re: Help ID this part
    I think it is the temperature sensor that disables the overdrive of the automatic gearbox when the engine is cool.
    Name:  od sensor.jpg
  20. #320
    Nov 2017
    Brockport NY
    Thank you! I had someone tell me that but I needed to confirm. Appreciate your tesponse!!
