I've decided it's time to sell my van. I've had it for about a year and a half and I originally had big dreams of turning it into a camper, but school has started to dominate my life as of late and I don't have the bandwidth to give it the attention it needs. I've had the van up on FB and offer up since the beginning of summer but I spent sometime abroad and didn't reply to any messages. The inside is basically gutted, and there is a wood platform inside. I have 2 manilla folders of work that has been done to it since it it left the lot in Eugene, OR. The original owner had a driveline disconnect installed so I assume the high mileage was because it was towed but this could be speculation.
It comes with an additional ignitor assembly, EGR modulator, cold start injector, vacuum switching valve and an oil pressure switch.
Comes with Yakima 60" round bar roof rack.
Tags expire at the end of October, but I expect a clean DEQ
1989 Toyota Van
265,000 mi
2 wheel drive
Automatic Transmission
I'm looking for 3,000 and I am open to reasonable offers. Let me know if you have any questions.
Work done since I've owned it:
Oil/Filter 10w30 - 3/1/21 Plugs/wires - 3/12/21 Distributor cap - 3/12/21 Rotor - 3/12/21 Air Filter - 3/12/21 Fuel filter - 3/20/21 Power Steering Belt - 3/20/21 Power Steering Pressure Line - 7/17/21 Serpentine Belt - 7/17/21 Change coolant - 5/29/21 Thermostat - 5/29/21 Thermostat Gasket (OEM Toyota) - 5/29/21 Coolant temp sensor - 5/29/21 Temp sending switch- 5/29/21 Coolant hoses- 7/21/21 Front Sway Bar end links/bushings 3/6/21 Front shocks - 3/6/21 Right Upper ball joint - 3/27/21 Right Lower ball joint - 3/27/21 Left upper control arm w/ ball joint - 5/8/21 Left lower ball joint - 4/7/21 Lower Control arm bushings - 5/15/21 Right upper control arm - 5/30/21 Oxygen sensor: upstream - 5/2/21 Oxygen sensor: Downstream - 5/2/21 Throttle Position Sensor - 5/2/21 Throttle position sensor connector - 5/2/21 Differential fluid change 75w90 - 7/22/21 Speedometer Cable - 7/6/21 New Seat belt - 7/6/21 Rad overflow sensor - 7/15/21 Oil level sensor - 7/15/21
It needs:
Exhaust gaskets replaced (included)
New muffler - current one has a couple holes
Front brakes and Rotors
New front windshield
S0... I know it's 2.5 yrs later... but: do U still have this & is it still OK & still for sale???
I have had 2-3 of these & would like another one (running & OK). I have a '91 Previa now
to trade or sale. I have had 3 Previa's in past. Prefer the LE, but most are trashed or just used up>
pls e-me soonest. GETTOCAR. pgjonx@gmail.com
