Results 1 to 8 of 8
Thread: Fast idle in park or neutral
    1997 Previa
    Jan 2025
    Morro Bay
    Hi all – happy to be part of the Previa community – I never even knew what this car was until recently when I got one for quite cheap as a non-runner – I played with the throttle body and made sure there was gas and I was able to get the car started and it’s been running great
    I do have one issue though – it has a high fast idle in park or neutral no matter how warm the engine is – this is causing me grief at the moment as I need to pass smog in California and they won’t let you do the test if you have a fast idle in park –
    I’ve replaced the throttle position sensor and I fiddled with the throttle adjustment screws, etc. – but it just seems like it always wants to be fast idle in park – does anyone have any tips or clues for me to try out?
    I have the cool 1997 Alltrak model (I think they only produced 4000 of these this year?) - with leather seats etc - she has around 220k miles and abit rough exterior and interior but every time I drive this van it puts a smile on my face
    I think the idle is around 1500 - but settles down when I go into drive etc
    Any help appreciated
    One big clue - after I got the car, I noticed it was actually missing its ECU - I was able to get one from another 1997 Previa (that had a huge sun roof btw pretty cool) and installed - but I notice neither of my code readers detects the ecu
    I don’t see a check engine light on dash
    So my theory at moment is if I can get the ECU fully connected/working with the Previa - perhaps the idle will settle down. Ok thanks for any advice/wisdom
    Re: Fast idle in park or neutral
    Are you sure you have the correct ecu?
    1997 Previa
    Jan 2025
    Morro Bay
    Hi - well it was definitely from a 1997 Previa from junkyard - mine is a 1997 Previa
    my understanding is the original one I got from this couple had someone working on an issue and that person had taken out the ECU – and then they couldn’t find it after they sold it to me – so I think the issue is there is a disconnect somewhere from the ECU to the van - and this may or may not be related to the high idle problem – I found the interest in the car, ran without major issue, even without an ECU altogether – but yeah, even after I plugged one in, I’m not getting any reading on my code readers – so my plan is to trace all the wires to the ECU and see if there’s a disconnect somewhere (I already checked all the fuses)
    again, this may or may not have anything to do with a high idle issue, but it is definitely something that needs to be addressed at some point
    1995 Previa SC 1996 Previa SC 2001 Sienna
    Jan 2025
    Richmond Ca
    Hiya. I just got my second Previa and I'm dealing with the same thing (except my smog guy passed me with a warning). Does yours have the supercharger? Are you ready for a bunch of very helpful people to fill you in about the IACV and "black flakes" issue. You'll have some reading to do. That's how I ended up here.
    1997 Previa
    Jan 2025
    Morro Bay
    Hi thanks for sharing your input
    I could be wrong, but I think all 94 to 97 previous come with the supercharger by default – but if I’m wrong, please someone correct me :-)
    So yeah, I have a supercharger – I read something about the black flakes issue – when I took out the throttle body there was this metal tube connected to it – I didn’t really see anything that seemed like black flakes, but maybe I’m not doing it right – I think what I’ll do now is research more on the black flake issue
    It’s strange for me to think how black flakes would be involved in a high idle – but I guess there’s something to it – thanks for pointing me in that direction again
    Yeah, here in California they don’t mess around with the smog – it has to be really right for them the pass yours - I really want to get this van back on the road soon – I find that the Previa is a super cool ahead of its time van – but I also get the feeling it’s good/requires to have mechanical skills to keep it going
    Mine does have 220k miles - hoping to go another 220!
    Jan 2025
    Richmond Ca
    Did you already find this thread?
    '97 Previa RWD VERY HIGH IDLE Warm Engine
    1997 Previa
    Jan 2025
    Morro Bay
    Thanks for the tip on that link – I’m now reviewing it and going to try the most likely causes first after I read through this – thanks
    Jan 2025
    Richmond Ca
    Did you figure out what was causing your high idle? I cleaned my throttle body, replaced the IACV, and can't find a vacuum leak. No improvement. I'm still idling around 1500 in park, 800 in drive, and getting 12-13mpg.
