Results 21 to 23 of 23
Thread: ignition cylinder, replace ignition cylinder, key broke off
    Re: broken key in ignition!
    Quote Originally Posted by Toyovan View Post
    Tim. I lost my 1 and only key for my 84 van. Currently I am using a flat head to turn the van on. The cylinder was bad prior. What's the best way to get 1 key for the ignition, doors and gas door?
    Back when I worked for Toyota (in the late 80's) we had a key punch tool that could make keys for any Toyota by only knowing the VIN. Understandably the VIN to key code info and those punch tools were guarded. That was also a long time ago and not sure that info and or knowledge to punch out new keys that way still exists. If it does, and you find somebody able to do it, that would be the easiest. Otherwise, the next easiest method would be to remove a lock cylinder from one of the van doors and take it to a locksmith. They can open it up and fabricate a key to match. If one key worked on every lock before, the new key they make will do the same. Not sure what locksmiths charge anymore, but a competent one can do that job in about 15 - 20 minutes. Tim
    PS: If you're replacing the ignition tumbler, take the new one in with the door lock and have the new tumbler keyed to match at the same time.
    1984 van le
    Mar 2022
    Houston
    Sweet didn't know they could do that. I've tried looking for a ignition tumbler for my 84 van but no luck. Do you know where to get 1?
    Re: ignition cylinder, replace ignition cylinder, key broke off
    I just searched the internet and it appears there's nothing available anymore. I checked for both OEM and Aftermarket. Your results may vary, but this is becoming more and more of problem with these vans. Tim
