Well I THOUGHT I'd be able to get the oil pan out of my 89 Diesel MasterAce 4wd through the bottom, but it's about 2mm too long!
I took off the sway bar, but the frame bar that holds the engine mounts is in the way in the back, and the cross member is in the way in the front.
Has anyone else got theirs out without removing the engine? It almost looks like maybe I could pull it out from the front if I remove the coolant lines and the oil strainer?
