aluminium 2wd radiators on ebay
FYI
I spotted these on ebay: https://www.ebay.com/itm/146686902940
I ordered one, when it is in, I'll post a comparison picture with the original toyota one. The dimensions and connections seem to be the same. Looks like it also has the clips and holes for the fan shroud.
Jan-Willem
Re: aluminium 2wd radiators on ebay
It is a perfect match.
it also seems solidly built. The core is thick, and so is the aluminium they used for the tanks, all the mountings are in the same spot as the original. The welding won’t win any prizes, but they used a lot of it.
The core is a little ehmm shorter than the original one,but they added a bit of frame on the bottom to make it fit.
I am happy with it
Wow! They have radiators for some relatively obscure vehicles and reasonably priced. If only they had the 4WD version for the vans.
