It's a keyed connection to the TPS, so it won't go on wrong unless there's damage to the connection. The last time I did this (the one where I shot the video) I also got a TPS code afterward. I then checked the timing and checked for it to advance when I pulled the jumper out of the "check engine" connector. The timing didn't advance so I was like "damn, did I get a bad TPS?". Upon further inspection I realized I had forgotten to plug the harness into the TPS. I'm happy to report the problems went away as soon as I plugged in the TPS. You should definitely check the condition of the harness connection there. I'm not sure what else to tell you. Sometimes these type issues can be a real PITA to diagnose and repair. The good news is you're starting to run out of things to fix. Once you find and fix the real issue you'll have a practically new van
. Tim
. Tim
. Eventually you have enough spare parts that you can swap them around to test future issues
. If you have the space, having a parts van around can be very, very beneficial at times. Good luck. Tim
For the first time ever I dont have any knocking or pinging.
