I need to purchase a multimeter. For the meantime I alternatively jumped the wire from the headlight fuse to the oil level relay and the van also started fine. I need a wiring diagram to pinpoint the possible break in the link. Is the jumper cable allowing the bypass of the fuel pump relay? I Do not hear/feel a click from the fuel pump relay on the firewall. Thanks.
