I havent been a CA resident in a while but SMOG is intense NOW!!!
In NV its just an emissions test. IN CA they do all kinds of extra tests.
Any how my van had very high CO and HCs.
I also failed on ERG modulator not delivering vacuum to the EGR. I see in the manual that there is a filter that needs to be cleaned. and I need to check the VSV or bypass it for my next test.
I will change the air filter and check plugs.
Anything else???
THANKS!!!!
). Internal damage such as broken ceramic mesh can also prevent the cat from doing it's job (but not as bad as having a clogged cat). One more thing to consider in the "vacuum leak" category is mixed up or improperly routed vacuum hoses. Check the vacuum hose schematic and verify they are going to the correct ports. Having high HC's due to low compression is not very common. Not much you can do about it anyhow (short of a full rebuild), so unless it's bad enough to make the van run rough, I'd probably ignore that and concentrate on the things you can fix. It sounds like you're well on your way to completing the list & I'm guessing it will pass once you're done. Good luck. Tim
