ToyotaVanTech Forums - Powered by vBulletin
  • Register
  • Help
  • What's New?
  • Articles
    • TVT Vanwagon Owner's Manual
    • TVT Previa Owner's Manual
    • Tim's Tech Tips
  • Forum
  • Blogs
  • Advanced Search
  • Library
  • Home
  • Tim's Tech Tips
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
  • Section Widget
    • Van Technical Information
      • TVT Van Service Manual
        • Maintenance
        • Engine Mechanical
        • Emission Control Systems
        • EFI System
        • Cooling System
        • Lubrication System
        • Ignition System
        • Starting System
        • Charging System
        • Clutch
        • Manual Transmission
        • Automatic Transmission
        • Transfer
        • Propeller Shaft
        • Front Axle and Suspension
        • Rear Axle and Suspension
        • Brake System
        • Steering
        • Body — Electrical System
        • Body
        • Air Conditioning System
        • Service Specifications
        • Standard Bolt Torque Specs
        • Electrical Wiring
      • Tech and Performance Mods (Vanwagon)
      • Custom Van Projects
      • TVT Previa Service Manual
      • Tech and Performance Mods (Previa)
      • Custom Previa Projects
    • Van Parts
      • Vanwagon Collision Catalog
      • OEM Van Part Numbers and Availability
      • Aftermarket Part Sources — Vanwagon
      • Parts Interchangability for Vans
      • Van-compatible Accessories
    • Previa Parts
      • Previa Collision Catalog
      • OEM Previa Part Numbers and Availability
      • Aftermarket Part Sources — Previa
      • Parts Interchangability for Previas
      • Previa-compatible Accessories
    • Van Historical Information
      • OEM Van Dealer Literature (links)
      • Vanwagon — external information links
      • Vanwagon articles and videos
        • TVT member articles — Vanwagon history
        • Vanwagon articles and press releases
        • Videos — Vanwagon commercials
        • Videos — Vanwagon, other
    • Previa Historical Information
      • OEM Previa Dealer Literature (links)
      • Previa — external information links
      • Previa articles and videos
        • TVT member articles — Previa history
        • Previa articles and press releases
        • Videos — Previa commercials
        • Videos — Previa, other
    • Tim's Tech Tips
  • Categories Widget (Show All)
  • Tim's Tech Tips
    Cleaning the Throttle Body
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    The throttle body is a pretty simple component but after years of service the internal passages can become clogged/dirty ...
    Read More Read More
    Starter clicks but won't crank!
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    There are several possibilities here, but before doing anything, inspect your battery cables and terminal ends to make sure ...
    Read More Read More 2 Comments
    Fusible links
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    The FL 1.25B fusible link is a common problem area on these vans. To start with it's in an odd place. It's tucked up in ...
    Read More Read More 1 Comment
    Testing fuel system / replacing fuel pressure regulator
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    Published on 01-08-2012 02:04 PM
    1. Categories:
    2. Article
    For testing the fuel system I'm using Harbor Freight's cheap Injector Pump Test Kit. The van I'm testing is an 89 2wd cargo ...
    Read More Read More
    Tires, tires, tires!
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Article Preview
    A common question is "what size & type tires will work best for me?". Well, lets start out with recommended ...
    Read More Read More 5 Comments
    Heat soak / Hot soak
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    There is a sequence of events and certain conditions that lead up to hot soak. It's hard to accurately duplicate these conditions ...
    Read More Read More 6 Comments
    Other parts to replace while replacing Head Gasket
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    1. Categories:
    2. Article
    Please read Diagnosing Head Gasket Failure before getting started (if it ain't broke, then don't fix it). Okay, so you've ...
    Read More Read More
    How to replace your ball joints in about 2 hrs (2wd)
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    Published on 10-08-2010 02:30 AM
    Have you ever got an estimate from a shop to replace ball joints? If so, then you know this isn't a cheap job. What they ...
    Read More Read More
    Drive shafts and u-joints
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    Published on 10-02-2010 01:27 AM
    1. Categories:
    2. Article
    Article Preview
    If you have an 84 or an 85 van, then you are in good shape. Toyota made your u-joints replaceable. This means any reputable ...
    Read More Read More
    A few tricks for removing broken exhaust studs
    • View Profile
    • View Forum Posts
    • View Blog Entries
    • View Articles
    Published on 09-16-2010 04:56 AM
    1. Categories:
    2. Article
    Article Preview
    Well, I finally decided to do something about that annoying exhaust leak, so I tore down the van and found I have a cracked ...
    Read More Read More
      Make a Donation
    • Contact Us
    • ToyotaVanTech
    • Archive
    • Top
    Powered by vBulletin® Version 4.2.5
    Copyright © 2023 vBulletin Solutions Inc. All rights reserved.
    2010 - ToyVan Support Group LLC
