I've noticed my oil level light (not the oil pressure) has been coming on and off, acting finicky. Checked the oil, and it's up where it needs to be. Had my mechanic buddy look at it, and he agreed that the sensor was probably going bad. Also, it's seeping oil where it plugs into the pan... nothing major, but making a mess of things down there.
Found a gasket for a $1.37: https://www.1sttoyotaparts.com/oempartscat.html
Found the sensor for $195.21: https://www.1sttoyotaparts.com/oempartscat.html
Anyone know if this part can be had for less somewhere? Or is that the best I can expect, assuming it is actually in stock? I'd go to a salvage for one, but they've smashed all of the vans locally. And on my list of stuff to fix, there are plenty of other things that would come before throwing close to $200 at an oil level sensor, when I could easily ignore the light and check my oil regularly. Maybe I should just replace the gasket next oil change, to stop the leak. It would be nice to at least get that mess cleaned up, so if any leaks that are more serious were to happen, it's easier to spot them.
