Results 1 to 16 of 16
Thread: Lift gate / rear hatch lock cylinder
    '88 Cargo 4x4
    Dec 2017
    mn
    Hi all, I'm a new Van owner and the lock cylinder is non-functional in my hatch. I can't figure out how to remove the thing. I've tried lubricating it and the locking mechanisms to no avail.
    93 Toyota townace 4x4
    Nov 2017
    Sweden
    Re: Removing the hatch's lock cylinder?
    by hatch do you mean the back door?
    if so take the interior trim panel off and all the chains will be exposed. there is a push rod going don to the catch at the bottom. get some pliers on it and pull it up! if it won't move due to the lock then just pop the plastic clip off it where it joins the lock mechanism then it should work freely.
    be careful though they are often brittle with age!
    Toyota van LE
    Dec 2017
    Holland
    change the cylinder core of the back door.
    Hey,
    Are the doorlock cylinder cores interchangeable. I got a 1986 LE van.
    Can I replace the backdoor cylinder core with the cylinder core of a front door or sliding door?
    greetings JP
    1988 LE Van 4x4
    Mar 2018
    Portland, OR
    Re: change the cylinder core of the back door.
    I'm also curious about this. My 88 has 2 bad door cylinders that just hang there, looking like they're ready to fall out.
    4x4 Cargo
    Cedar City, UT
    Not sure about the LE or power locks, but i removed all the lock cores on my 87 cargo (with manual locks) to have them cleaned and re-cored by a locksmith, and they all looked exactly the same.
    Toyota van LE
    Dec 2017
    Holland
Size:  76.8 KBThis is the rear door lock cylinder as it came out of my '86 californian van LE.
Size:  92.6 KBOn the left the back-door lock cylinder and on the right a front door lock cylinder. You see the difference, they are also not interchangeable.
Size:  76.1 KBThan i took the backdoor lock of my European Van (Model-F), also 1986. The complete locks are interchangeable, but not the cylinders
    greetings JP
    Feb 2016
    Los Angeles, California
    Does anyone have an after-market part # for the back door cylinder?
    I'm looking to replace a manual lock on my 89, Thank you!
    4x4 Cargo
    Cedar City, UT
    I correct my earlier statement. The rear lock core is different. Mine looked like the photo above. Its exposed to the elements and gets clogged up extremely easy. I was able to have the locksmith clean it up and recore it along with my others so it was working again (until I went on a really dusty road - now its clogged again lol)
    As far as part number, I dont have it but IIRC they are NLA? Not 100% sure on that, but you could also get one used off another van or have a locksmith dissemble it and clean it up and get it working again and matched to your key...
    Forum Newbie Papay's Avatar
    Liteace KM30
    Nov 2018
    Philippines
    Quote Originally Posted by spacecruisers View Post
    I bought a complete set of new lock cylinders with keys and ignition cylinder, on eBay, similar to this pic. I think it came from Australia. Dude has an eBay store with a selection of the things, which seem either Malaysian or Chinese. They were a direct fit, but I had to swap the little metal 'flag' tab on some of them. Presumably Toyota used them for various model vans and trucks.
    Feb 2016
    Quote Originally Posted by Papay View Post
    Any chance you have that eBay link or part number? I need to swap the cylinder on the back hatch
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Re: Lift gate / rear hatch lock cylinder
    They sell lock cylinder's for our vans on Amazon.
    https://www.amazon.com/PT-Auto-Wareh...=lock+cylinder
    They were used on several models... trucks, corollas and so on.
    I haven't seen any combo sets, but it's a simple job for any decent locksmith to match the cylinder's and an ignition.
    Heres the ignition, also from Amazon.
    https://www.amazon.com/Standard-Moto...3Atoyota%3Avan
    And is your name Johnny Delgado by chance?
    Feb 2016
    Right on! Thank you.
    Jonathan but close enough haha, Have we met at a car show or something?
    Aug 2016
    Lakeside, Az.
    Quote Originally Posted by Jdelgado View Post
    I knew a Johnny D. in SoCal quite a while back... Refinery Worker.
    As for the lock cylinders, it's on my list to replace them all w a new, not worn out set up. My Locksmith said bring them and he can make them all keyed the same. Apparently these are fairly simple.
    Ivory 1987 Manual 4WD
    Sep 2015
    nowhere, everywhere
    just so everyone knows this is for the doors, NOT the rear hatch lock.. i stupidly misread that and ordered it thinking it was the hatch lock. didn't notice until i tried to install and felt like a dingus >_<
    does anyone know how / specifications to find one for the rear hatch lock? (the longer one in the photos on this thread)
    my hatch handle i got off a van at a scrap yard, but i have an 87. which brings me back to my occasional wondering of if there are different body parts within the same year?
    White 89 LE, 2WD.
    Feb 2016
    SF
    This is not so much a cylinder question as it is a back door question. I've noticed that there seems to be more and more play in the door when going over bumps. It's sounds like it's shaking/rattling. However, when it shuts, it feels like its seated all the way closed, tightly. Is there something within the latch or hinges I can do to stop the rattling, or is this just the rubber wearing out?
    -Terry
    There are 2 methods of adjustment
    On either side of the door there are round, rubber coated cup washers that line up with the U-shaped receivers on the body.
    The cup washers are adjustable to a degree and if the rubber is worn new ones were still available a couple of years ago.
    Stupid expensive mind you, but....
    The 2nd method involves messaging the receiver loop on the floor, with a Ford hammer
    I tried the 2nd method first with only slight improvement.
    Then spent my money and enjoyed the quietude,
    YMMV
