Hello All,
The van only makes the noise while under power going up steep hills, when it is bogging down. The rattle is constant and goes away after getting over the incline. It happens in all gears, but in the similar situation described above.
It does not make the noise when revving the motor in neutral. There is a tapping sound at start up the goes away when warm. Could it be a lifter?
Anther weird thing is that the E-brake light comes on when shifting at higher RPMs![]()
. Not such a big deal for general things but EFI/Emission problems it's particularly important as to help avoid confusion (several major changes made throughout the years).
