Based on your description, I think you likely have a shorted diode in your alternator. An alternator with a shorted diode will still charge, but it will allow current to flow both ways. This means it will suck the power back out after the van is shut off. If the previously outlined checks are inconclusive, then go to the little black + box (drivers side engine compartment near the MAF) and disconnect the big wire going into it (that's your alternator output cable). If the load goes away with that disconnected then your problem is in the alternator. Good luck. Tim
PS: A shorted diode will pull about 5 - 10A, so if you're detecting that kind of draw I'd bypass the other checks and go right to the alternator test. Be careful not to ground out any wires when messing with the + box. Be aware that steel tools conduct electricity
